turbinedoctor
- Sep 7, 2009
- 225
I am trying to help out a friend who has a GM 120MR engine in his boat. We are converting from point ignition system to electronic with a Pertronix's ignitor kit. While looking over the wiring diagram for his engine I have a question or two about the Resistor wire and the Purple/Yellow wire to the starter. I think the Purple /Yellow wire is called a Ballast bypass wire but am unsure as to it's job. The resistance wire is to drop the voltage to the coil ineffect lowering the current in the circuit to about 3 or 4 amps, is this correct? The kit said to connect the red wire to the 12 volt before the resistor wire for full voltage. He connected it after the resistance wire and the engine only back fires when trying to start. Please forgive the second and third hand information here as I am trying to help and have only seen the engine once.
