swcejk2002
Thread starter- Joined
- Aug 20, 2009
- 45
Hello forum. I have an older aq125b Volvo penta I am resurrecting. I have it on a stand and am trying to get her to start. It took me a while but I FINALLY have spark at the distributor and at the plugs. But I am Pretty sure I am NOT getting any fuel into carb and to plugs... I have TWO batteries set up and am using jumper cables to get her to crank. I have a wire with alligator clips to jump a hot point (on the slave(?))...to the purple + on the coil. (in first picture).....
In this second picture (ingenious), I have a black hose coming down from above, on a shelf I have a small gas can, I siphoned the fuel and attached the hose to the fuel pump.
I am getting a small drip of fuel where the fuel line enters the carb, so I know I am getting fuel up to that point. I am including this picture of the starter, I hope I am having the wires hooked up right.
Lastly, I see that there is a small clear hose on the back side of the carb, I am wondering if I should see fuel come out at this point...
I am trying to crank here over and get a smidgen of hope that she'll start (and ultimatly run). I REALLY want to work out as many bugs as I can before I even think of putting back into the boat.
