1977 Merc 85 hp lower unit parts and compatibility
rcam97
Just got my 1977 merc 850 inline 4 cylinder running real good. Took it out on the river tuned the carbs in and rode the river about 10 minutes. Then it happened, the engine started bucking and banging. So I shut it down, loaded up, took the lower unit off, and we have found that there must be some teeth stripped off of the foward gear because when you turn the drive shaft by hand in foward gear the prop will slip every once in a while. I am gonna tear it down and find what exactly is wrong in there. So my question is does anyone know where I can get new gears for this thing or even better some used ones? Also I think heard that the inline 6 lower units will work as well, is this true?
rcam97
Re: 1977 Merc 85 hp lower unit parts and compatibility
Does anyone know if any of the inline 6 lower units will work?
Droll
Any of the inline 6 lower units produced between 1972 and 1988 will bolt on... BUT they got an other gear ratio than the inline 4 engines ( WILL require a different propeller pitch )...
Arne Kjetil
rcam97
Thanks a bunch. I currently have a 19 pitch prop. So would I go to up in pitch to a 21 or down to a 17 pitch?
