I'm almost ready for the water. just a few minor details left. I tried this question in the Johnson motor section and the electrical section without much luck. I thought I'd check here for some advice. I have a '63 Johnson 40 hp electric start that is hanging on the back of the boat now and I installed a new key switch. the key switch has a terminal that is labeled M this terminal has continuity with ground when the switch is turned off. I assume this is to kill the engine. If that assumption is correct what in the engine do i hook it to? This engine is long past having color coded wiring, it's been to too many shade tree mechanics before I got hold of it.
http://s659.photobucket.com/home/jambla/allalbums
