FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
hello there I have a mercruiser wellcraft 232 eclipse with a 228/305 and a SE116, with a rochester 4 barrel carburetor, engine runs great but doesnt go over 3200 rpm going forward what can cuse this? Im using a 4 blade prop 14-19-21. thanks.
yes I did engine has been tune up about a month ago, new plugs, new cap, new wires, carburetor was rebuild, new fuel pump been installed, outdrive is 1.5 ratio, the prop is barely new, So i think probably the thrrottle cable need to be adjust or should I changed the prop.
Ayuh,... Diagnostics is the methodological working through a list of ALL the possiblities...
Don't just cherry pick the easy answers, then whine when you don't find the Problem...
Somewhere in Don's list I linked to is the Answer to your question...
Just because you have a NEW prop, doesn't make it the correct prop.
What happens with your original prop.
Same with the carb, just because it was rebuilt doesn't make it good. and it has nothing to do with a problem with the fuel tank or lines to the engine.
thanks Don Ok original prop, not available when I bought the boat didnt have a outdrive, fuel lines are brand new, this prop was used in my other boat, 22 cruiser same engine and never have this problem?So I thinking this pop is not correct for this type of boat.
Sounds like prop. 4 blade 14" x 21" is too high of a pitch. Probably need a 4x14"x17" if you want to stay with a 4 blade if not a 3 blade 14"x19" is probably what should be on the motor. If you drop the pitch to 17" from a 21" you should gain 600 - 800 RPMs with a 4 blade. This is assuming the engine is running in top shape timing, fuel, etc...
You also posted in the prop forum. Go there for suggestions. Who did the tune-up and carb rebuild? Was timing properly set? I guess so is not a good answer.
the tune up was done in the shop and I recheck the timing is good, engine sound and look good. I will try to change the pitch and see how goes thanks guys.
