dolphinhunter
Thread starter- Joined
- Mar 10, 2009
- 27
Hey guys I have a lovely 150hp frankenmerc that the only thing i know for sure about it has an 86 mariner 150 power head. I was told this thing was an 93 and has the tilt trim and cowling of one. To the point now. I'm trying to solve the bad load up i have on this motor at idle. I run premix and 89 or better octane. The carbs are squeaky clean as of 2 months ago. The motor stays rich untill about 2-2200 rpm than it finally starts to clear out. (just a tiny bit fast for the trolling i do) i know these motors don't like to go slow but i can also smell the fuel in the exhaust when it idles. my goal is smooth running at 15-1800 range. When i sea foam out the motor she leaves behind a nice black oil slick through the exhaust. As soon as i can get my hands on a timing light i'm going to check it. i have cynced the carbs already. Also should i time it to 86 spec or go with the 89 and up manual i have now? what's a good ethanol bump 2* or so? do i need to change idle jets possibly? Or should the timing clean this up? Also which ngk non surface gap plugs can i use. That should also help a bit right? If not i'd like to know anyway cause i don't really like surface gap plugs.
Thanks
Thanks
