1965 60HP Johnson Replacement Carburetor
boldtr
I have a 1965 60HP Johnson Seahorse (Model VXL-11C). My carburetor has high-speed adjustment needle valves. One of the two high-speed orifices (jets) was stuck and damaged and cannot be drilled out. (broke off an easy out in the orifice!). The other orifice came out very easily.
I will not be trying to remove any orifices (jets) in the future if they appear clear and clean.
I am now looking for a replacment carb and found some on eBay. I noticed that on "newer" models, (ie 1968) they have removed the high speed needles and have fixed high-speed jets. Can I mount one of these 1968 carbs on my 1965. I checked the gasket PNs and they are the same so it appears it wil fit on my intake. The other concern is throttle linkage.
Why did OMC move to fixed high-speed jets. Will this setup be too rich or lean for my motor. Do I need high speed needle valves for my motor?
tashasdaddy
Re: 1965 60HP Johnson Replacement Carburetor
cannot answer the question about the carbs, but here are possible sources.
SALVAGE YARDS
Try some of these:
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
budgetboats.net
americanoutboard.com
piratemarinesalvage.com
trixieslanding.com
mmmarinesalvage.com
tcoutboards.com
F_R
I don't know if the throttle linkage will work or not. I suppose if the hookups all fit it will work as long as it is a 60 or 65 hp. They went to fixed jets because nobody could adjust the needle type nearly as well as the fixed jets automatically are.
