5.0L Merc Cooling system
jetmart
Is there a drawing of how the cooling water flows from the lower end, through the pump, engine, exhaust and back out?
I have a thru hull exhaust. I am use to outboards with a tattle tail indicating everything is fine.
Re: 5.0L Merc Cooling system
Ayuh,... The 5.0l has been used by Merc for over 20 years,+ with several different cooling systems...
You need to provide More info about Your's...
jetmart
1999 5.0L EFI with alpha 1 gen 11 ser# L347633
Ayuh,... Up in the Adults Only section of this forum are the Factory Manuals,...
Complete with Pictures,...
Have a Look...
jetmart
Thanks found it in manual #24 page 6A-26. This shows all the water being discharged through the exhausts. Is this correct? I have through Hull exhaust and there just doesn't seem to be a lot of water flowing. Does anything exit out the lower end?
Engine temps are good and impeller and housing is 1 year and installed by professionals.
Ayuh,... That is Correct...
If in doubt, change the Impeller...
