Please help a newbie. 1990 Force 90 HP
Kenro
After draining my lower unit for lube change, I stupidly saw the other bolt head on the right Bottom.(From the rear view of the engine. I thought I had not got "both" drain plugs and started to turn this bolt. I immediately stopped when I realized what I was doing. I had turned approx. a 1/4 turn. What is this bolt head for and how bad did I screw this up?
Thanks,
Ken
Kenro
Re: Please help a newbie. 1990 Force 90 HP
I have identified the screw as the shift pivot screw. Is this an adjustment screw?
Thank you,
Ken
pnwboat
As long as you didn't remove it completely, you're OK. It's a pivot pin that goes through a pivot arm. No adjustment here. It just gets screwed in place and tightened up so that it doesn't fall out.
Kenro
Thank you. what was weird is it turned clockwise. it is not left handed thread, is it?
pnwboat
Not 100% sure because I've never touched mine.
