Clipper Circuit
72seastar
I have a 1972 Johnson 65 HP and am not getting a charge to the battery the engine runs fine and i have the manual on how to test the clipper circuit and rectifier and all that but i have no idea where the clipper circuit is or what it is really.... there are no pictures showing what it looks like on the engine or where its at and really what it does im at a loss here
72seastar
Clipper Circuit
72SideWinderSS
Re: Clipper Circuit
on my 72 Evinrude (If I remember correctly) it was in the control box, and it just comprises of a diode.
72seastar
Re: Clipper Circuit
now by control box do you mean the power block with the 12 terminals or the strip thing above the power block
72SideWinderSS
Re: Clipper Circuit
No, not on the motor, In the control box that contains the throttle lever and shift buttons (where you control the motor when you are driving). It seems to me mine was lodged in under the shift buttons.
osborn159
Re: Clipper Circuit
try posting on the outboard forums, they probly will move this, dont think youll get much response here. were all covered in f/g dust and got resin stuck to our arms.
F_R
Re: Clipper Circuit
Whoa guys----too much mis-information here.
1. There is no clipper circuit on a 1972 65hp. Doesn't need one because it has mag CD ignition.
2. If it did have one, it would be on the powerhead, not in the control box. That diode in the control box is called a blocking diode and has an entirely different purpose.
3. There is no blocking diode on a 1972 65hp. Same reason as #1
ezeke
Re: Clipper Circuit
You do have at least an unregulated rectifier and if it is bad or missing then you will not have a charge.
You can test it using the method outlined here: http://forums.iboats.com/showthread.php?t=190638
Bob_VT
Re: Clipper Circuit
merged posts
72seastar
Re: Clipper Circuit
i also read that these engines have a 9 amp charging system or something how do i convert it to the 15 amp system or more for that matter to run accessories im going to be installing a livewell and will need to be able to power the lights, arreator, bilge, radio, and be able to charge the battery
72seastar
Re: Clipper Circuit
what type of charging system is on a 1972 65HP generator or alternator and where is it located?
F_R
Re: Clipper Circuit
It is an alternator and the heart of it is the stator located under the flywheel. The 3 big coils charge the ignition system and the 6 small ones charge the battery. The rectifier, previous picture posted, converts the AC produced in the stator to DC for charging the battery.
Couldn't get a picture of the correct stator for your motor but this is similar:
72seastar
Re: Clipper Circuit
thanks so if the battery isnt getting a charge but the motor runs its more than likely the rectifier is shot then right
Tim Frank
Re: Clipper Circuit
Still many permutations of possible faults. That's why you need a systematic approach to troubleshooting thse systems. Could still be the stator or something else.
Part replacement is an expensive sport even if you are playing the "home version" of the game...and trial and error is not the best way to do it....especially that vintage of motor. I had a slightly earlier version of that motor and blame many of my gray hairs on OMC's design group...:eek:;)
seahorse5
Re: Clipper Circuit
Are you reading from the right service manual and are you sure of your motor model and year? What is the model number?
The 60hp engine from previous 2 years used a clipper circuit with it's battery CD points-type ignition. The 65 has a Mag-Flash magneto powered CDI.
ezeke
Re: Clipper Circuit
That's correct. Besides, it's very easy to check an unregulated rectifier with an ohmmeter.
