fuel line and primer bulb size
86 charger
I have a 1986 Mercury Black max xr2 150. I am needing to know what size of fuel line and primer bulb to use from tank to motor? I have seen 3/8 and 5/16 sizes but I have also seen 1/4 inch. I want to know what is OEM for that motor, not sure what is on it now.
ClassyGlassy
Re: fuel line and primer bulb size
3/8" ID with subsequent Primer Bulb to go with it. Use a Low Permeation Marine Fuel Line......
Wal-Mart actually sells a kit of fuel line and bulb by Seasense that is perfect. Make sure you get the LOW PERMEATION one and not the standard one that Wal-Mart sells....price will be about a $10 difference.
j_martin
Get a genuine Mercury line and primer. The Aftermarket ones that I've tried will starve your engine just enough to burn it down.
achris
More fish than mountain goat
From a current MARINE mechanic, certified by Mercury to work on Mercury and Mercruiser.... USE GENUINE!!! and the biggest you can get hold of. Aftermarket warranties don't cover consequential damage, genuine does.
Chris......
Don S
Tubtoy and achris. If you two want to argue, use the PM function not someones post.
6 posts deleted
walleyehed
I'd like to see an end to the insults, NOW.
If you don't understand why....well, keep it up!
EDIT: Yer fast buddy...:)
Bob_VT
My apologies to the original poster. I deleted the bickering which is not normal here.
Yes the older Mercuries were fuel hungry and there had been reports of using a small fuel line does starve the motor. I was advised by Clams Canino Hartwell Marine (a great Mercury mechanic IMO) to use the larger line.
Your BEST bet would be to consult with your local Mercury mechanic and just ask.
Thanks for your patience...... there will be no more bickering in this thread.
achris
I believe the original line on the V6s was 3/8", anything smaller could starve the engine and cause denotation...
Chris..........
86 charger
I got the info. I needed. Thank you and I hope everyone feels better now!
I know I do.
