Boat fender clearance
Fishing56
Hi,
I have a Roadmaster single axle trailer that was custom made for my 1996 Mariah 18ft Shabah with a 4.3LX. The gvwr is 3500 and gawr is 3300 with 215/75r 14" tires. The problem is I have only 1/2" clearance on the tires and fenders. Has cut into the tires pretty severly.
About to replace tires. What would be the best and easiest way to raise the frame height? Shackles...spring lift kit?
Your comments will be appreciated.
Fishing56
By the way tires are Marathon load C rated at 1755 lbs each.
Fishing56
Re: Boat fender clearance
Thanks. Would I lose any weight capacity by going down?
Fishing56
robert graham
Maybe raise, modify or replace fenders, Northern Tool has plenty of fenders, don't cost much, easy to mount. Good Luck!
smokeonthewater
not as long as you buy tires with the same weight rating or higher
bruceb58
If you change the size of the tire down, you are definitley going to affect the weight rating of the tire if you are already at the max ply rating of the size you currently have.
Fishing56
Thanks to all. My first thought was to install either shackles or some type of lift block between the leaf sprind and the axle. Upon inspection, the both the top and bottom of leaf spring have notches in them for centering and stability I suppose.
The bottom stud is longer with a nut on it. This is where I need to place the spacer between the spring and axle. I did one side with two 2" washers. The frame was lowered down and I was able to line up and pop the stud into the hole in the axle. Tightened up ubolts ect. Thought about spot welding the washers onto the axle but haven't yet as it seems the connection was rigid.
Am I running an suspension failure risk with this approach? I can't see that the stress would be real high on the stud once it is aligned and clamped down.
Sorry about being too wordy,
Fishing56
PS. Shackel kits bolts were smaller than those on trailer, so was worried about strength and size difference with leaf springs.
Gary H NC
Are these the original springs on this trailer?
It is about 15 years old and hauls a heavy boat for a single axle.
It may be time to look into new springs.
Is it a constant tire rub or just when you hit rough pavement?
Fishing56
Tires are original tires, so they are going on 14 or 15 years. I have about 1/2 inch clearance, so only cuts a groove into thread on bumps etc. Think this problem was from the getgo, I just didn't realize it at the time. Of course if and cargo at all in boat, just makes it worse.
The washer install got me a 1" clearance, just not sure of the engineering.
Fishing56
Fishing56
Just a couple of footnotes for all:
Boat is always stored in garage.
Only about 5 miles to lake.
Tread wear on tires is less than 50%.
Thanks,
Fishing56
smokeonthewater
well I did a little checking and I couldn't find a 14" trailer tire smaller than a 205 which works out to be only .2" smaller in diameter than the 215.... I also didn't see any 13" tires with the propper weight rating so it looks like you do indeed need to lift the suspension or fenders....
I'm not sure what you were saying about axles washers and shackles... You can use lift blocks on a trailer but new springs might be a better idea..... I wouldn't mess with longer shackles though
Gary H NC
New springs with one extra leaf should cure the problem.
I would not feel good about using washers for spacers between the axle and spring.
Just a set of new springs with the same rating would really help.
smokeonthewater
AHHHHHHHHH no prob jus didn't get it..... I thought you were saying my comment was the iboats version of like..... LOL.... makes more sense now:D
