ficht problem
dasher
NEED HELP
i have a 2000 model 225 evinrude ficht. Took it out yesterday ran perfect for a while. Started back to the dock it would not get over roughly 3000 rpm. Is it in safe mode or fouled plug? Need ideas.
50's OMC
Re: ficht problem
We had the same problem with ours. It turned out to be the fuel pump. One thing that may help is installing Racor Fuel Filters. They sperate the water from the gas to prevent fuel pumps from going out and you can empty the water yourself.:)
ezeke
Re: ficht problem
NEED HELP
It's probably in S.L.O.W.; Check your cooling system.
I believe that overcharging can also trigger S.L.O.W. in your system.
Here's more: http://continuouswave.com/ubb/Forum3/HTML/011277.html
Fl_Richard
Re: ficht problem
Fuel pumps will happily pump water. The Racors keep the engine from ingesting it which is always bad :)
Faztbullet
Re: ficht problem
Water in fuel and S.L.O.W both kick on the engine lights...
dasher
Re: ficht problem
No lights or alarms came on at all. Thats what has me puzzled. But I will try all these things and see what happens. THANKS!
