Will acetone or toluene break down cured 3m 5200
knoell3
I have use 3m5200 to seal small leaks in the bottom of my aluminum bass boat and it worked good. I was going to spray some of that truck bedliner over that for a final seal and noticed it had toluene and acetone in it. Does anyone know if that will affect the cured 3m 5200?
Thanks.
Black as
Re: Will acetone or toluene break down cured 3m 5200
Thanks.
If its cured it will only make it go a little gummy on the surface but wont really affect it at all
Spinnaker
Thanks.
It wont touch it, but here is a product that will break it down.
http://www.marineformula.com/uses.htm
Bob_VT
Please do a search about using bedliner material for an aluminum boat.
If you ever have a future repair needed you will venture into a nightmare!
Some aluminum boat manufacturers were making this an option for a short time but dropper the process since it led to future problems. Unless the aluminum is prepped 100% properly there is a possibility of separation due to the way aluminum oxidizes.
Gluvit can be utilized inside or outside the hull. 3m5200 can be removed with a wire brush.
knoell3
Thanks for the responses folks. I am going to clean the seam with acetone and spray this stuff from bow to stern. Still have a slight leak and do believe this will seal it.
