Urgent! Need length for 74' Sea Ray SRV190
Fordiesel69
I am filling out my dockage rent form and for the life of me I see no specs on the internet or with any paperwork I have as to the total length. Can anyone give me the spec, or point me to a link. I don't want to loose this spot so time is an issue.
Thanks.
Silvertip
Re: Urgent! Need length for 74' Sea Ray SRV190
If you own a tape measure, measure it. Bow to stern down the middle of the vessle. Judging by the model number, I'd say it's a 19 footer.
Urgent! Need length for 74' Sea Ray SRV190 -1974 Sea Ray SRV 190 19' Closed Bow
Ayuh,... If 19' ain't close enough,... Go MEASURE it...
yjanray
well the centerline on my 79' SRV 190 on the brochure is 17'3".
I would imagine its about the same
Fordiesel69
Measuring is not an option, they want to see it somewhere in writing, otherwise I have to trailer it and have it signed off. Also it is not accessable right now anyways.
Thanks, hopefully the brochure works.
Silvertip
Well then, since you can't get at the boat to measure it, and you can't find published numbers, check the title, it normally states the length. But just incase you don't have one of those either, it took me about 20 seconds to find this --- right here on IBoats.
http://www.iboats.com/Sea_Ray_Boats__SRV-190__1974/bp/64b75879r2
smokeonthewater
many places will let you pay for the slip subject to aproval of your boat upon arrival.... I'd say ask them if you can buy at 19' and adjust as needed when you show up
livin4real
all the slips around here are a minimum 20' long, most starting at 30'. i can't see your place having a problem with a 19' boat either
