89 evinrude 30 temp sender removal
chicken1659
Hey guys i have a 1989 evinrude 30 E30ELCED CD2UL and have had problems with the S.L.O.W kicking in and horn beeping a constant beep so have decided to change the thermostat as i think it may be overheating (tell tale stream is good).I thought i might change the temp sender as well but i have hit a snag, cannot see how it is removed.I have taken off the water jacket/thermostat cover (14 bolts and i broke one in the head) removed a very old+salty thermostat, pulled back the rubber insert along the tan wire and can see the sender fairly deep in its blind hole but no hex for a socket or spanner or slot or circlip to undo or pull out, it seems to be pressed in or inserted with adhesive into to its own little machined housing on the side of the head.I was hoping one of you guys had an idea on how to get this little sucker out or how to test if it is working correctly would be better so i can leave it in.
thanks heaps!
ezeke
Re: 89 evinrude 30 temp sender removal
The temperature switch is sealed with the equivalent of 3M 847 to keep it waterproof. You would need to break the seal and pry the switch out.
The switch needs a solid ground and must be protected from water/corrosion.
chicken1659
thanks for your reply ezeke
any ideas on how to test it because i would rather leave it in than dig/break it out for no reason
ezeke
You test them by heating them in oil with a ohmmeter attached. You can check that they are not closed while in place with an ohmmeter.
