aussiechef
Thread starter- Joined
- Mar 7, 2010
- 3
Hi. I have just aquired a 1985 johnson seahorse 15hp. It hasn't been used in a few years. I have cleaned out the carb, replaced the spark plugs and fuel lines. After I prime the engine it starts and idles fine but it is not pumping fuel into the carb. Once the primed fuel runs out the engine dies. Do I need to replace the fuel pump?
Also, there is no water running out of the pee hole when I use the flush muffs. Should the water come out of the pee hole straight away or does it take some time. I have a feeling that I need a new water pump and impeller.
Thanks.
Thanks.
