cant get the flywheel off,broke grade 8 bolt
tx1961whaler
Re: cant get the flywheel off,broke grade 8 bolt
It will run fine without the generator, as you may take it off once you find out what the belt costs......
glassmaster68
thanks,,yeah fr wrote,,,,,61.41,,,,whew,,for a belt
bktheking
You'll learn something about boating, "ya gotta pay to play"
14ftgrumman
:DIf you have enough beer, you won't care if the flywheel comes off or not:)
GLPmike
I was able to free the flywheel on my 1968 with a puller and it didn't free until I gave it a few good hits with a mediium sized happer. I let it soak for a few days with liquid wrench penatrating oil.
I put some good tension on it with the puller and gave it a couple of raps and it popped free.
Good luck
bktheking
He got it off already , put the beer goggles away :eek:
kenmyfam
Well I am heading for a beer to celebrate it's removal !!!:D
bktheking
Ya , already on my second of the night, a little Keiths. BTW i'm going to look at that boat with the 9.9 on it tomorrow.
14ftgrumman
When putting it back together do not forget to TORQUE the flywheel nut with a TORQUE WRENCH to the specified torque value or you will shear off the flywheel key, gall the crank end and maybe break the points cam.
Do not ask how I know this.:redface:
1946Zephyr
Gotta tell this story (again). A guy came to our shop and bought a set of points. Looking in the box and finding the capsule he asked what it is for. My co-worker who was selling him the parts answered dead-seriously "You swallow that pill 15 minutes before installing the points. It dialates your eyeballs so you can set the points without a feeler gauge". Still wondering how long the grease affected his digestion.
I'll have to keep that in mind. I always wondered what that was for. The only drug that you can actually take with beer.:D:D:D
glassmaster68
ok,,this ddd things i did today,,,first,i was setting my points on the low side of the lobe,,,,kept taking the flywheel off numerous times checking all the armature apparatus,,,finally read the book a little closer and did the right thing,,,she had heaps of fire,,,,had to prime just a lil to get it flowing,,i had picked up a clean looking beer bottle and put some premix in there,,got a straw with the finger on it technique and put some in the carb,,,started up ran great,,then the carb started pouring gas out of the front,,maybe float stuck,,,,,i started walking to the truck to get my book to start troubleshooting and had the premix beer in my hand well,,like a habit,,i took a swig ,,a good one,,,then thought i was gonna die,,,after it was all over,,i got a good beer and was soo glad i had that mixed 50:1,,,cause pure gas wouldve sure killed me,,,
bktheking
HAHAHA nothing like little 50:1 to wash down the oil capsule, gas don't taste so good. Was like me a few weeks ago and taking a no look drag of my smoke and burning my upper lip. Was the fuel tank hooked up while you did this or was it just gas poured into the carb?
doni456
use a solution of 50% transmission fluid and 50% acetone instead of pb blaster or anything else. This has been proven to be the best solvent ever.
glassmaster68
yeah,fuel tank was hooked up,,i even let pressure off of the tank and tried it,,,same thing,,thinkin about the float or needle not seating,,,,yeah,if i knew i was gonna swig the gas,i wouldve just blew it into the carb instead of using the straw,,,man i feel really weird,,,burps are like 2 stroke exhaust,taste wise,,,dont smell as good
Mas
I was waiting for a drag on your cigarette too!
Mas
bktheking
Float sounds out of adjustment or hung up.
cajuncook1
Buddy,
If you swallowed a mouthful of gasoline/oil mix and your starting to feel weird, please call poision control or get an Emergency Room ASAP!!
National Poison Control Center at 1-800-222-1222.
Swallowing gasoline may cause damage to the linings of the mouth, throat, esophagus (food pipe), stomach, and intestines.
Hope your OK,
Cajuncook1
samo_ott
Ugh. Don't smoke!
1946Zephyr
I guess that is why I never put fuel mix in beer cans or bottles, because I like to drink a lot while I work.:D:D:D
Even while I'm half lit, fixing these old motors is as simple as taking a swig.:D:D
BigB9000
Live and learn.
I swallowed gas once, Burped it up for weeks!
Anyone that says they like the smell of gasoline has never swallowed it.
8-10 years later and it still haunts me.
A side note, i picked up a collection of syringes to aid in things like this. (no needles of course)
works good for sucking on vacuum lines, or, injecting gas into carbs, oil into cylinders, etc etc.
The gas will eat the plunger after a little while, but keeps gas out of my mouth.
