bryanwess2000
Thread starter- Joined
- Jul 16, 2008
- 240
Well I determined the cause of my engine failure. My newly acquired
starcraft had a recently rebuilt 90hp merc 3cyl. that blew the #2 piston
the second time I took it out. It caught the top piston ring in the exhaust
port. All I did initially was pull the powerhead off and pull the crankshaft
assembly to inspect the bores. Today after I got back from my first splash
of the starcraft with the merc V135 I decided to investigate the 90hp.
My first thought was the bores were too tight for the pistons as they
mic 3.375-3.376 and the wisecos' need extra clearance. I ruled that out
when the piston skirts mic'ed at 3.365, plenty of clearance. Also there
was no scuffing on the piston. It turns out the locator pins' hole was
machined in the wrong spot, about .009-.010 off compared to the other
2 pistons. Between that and the piston ring groove being a few thousandths
wider than the other two pistons it allowed the ring to move around to
the point the ring gap was in the exhaust port and bam engine failure.
I wonder if wiseco will at least send me a new piston kit, I kind of doubt
it considering I'm not the original purchaser. I know mistakes happen in
production machining but the locator pin is a very critical part of a 2 stroke
piston and should have strict quality control. I know if I do any rebuilds
in the future, which I plan to, I'll be thoroughly inspecting the pistons as
well as any other critical components.
