R/CBOONE2010
Thread starter- Joined
- Feb 25, 2010
- 2
i have been trying to make this engine run. It set for some time before I got my hands on it. I took carb off, it had stuff stuck in it so I cleaned it. The fuel tank is no good, it looks like it has 20 year old fuel in it, haha. I took it off, and I don't know if it would work, but I put a longer fuel line, going up and attached a little bowl of fuel, acting as fuel tank. Anyways, it would not start, or even hit, even after shooting little starter ffluid right in the cylinders. I finally took the pull starter off and used a drll on the crank nut, and after checking the plugs for spark, ithey were and putting gas in the cylinder it hit, it would pull itsself when the drill kept it spinning, other wise it would not run, it would hit till the fuel was burned. So my question is, the fuel thing i did with bowl, is that okay for now, can I use a fuel hose ran down to ground in a fuel can? and why can't I make this run at all. What should I do to try o make it run? What things do I check. also what is oil/fuel ratio? thanks for your help
