dark cloud
Thread starter- Joined
- Jan 26, 2009
- 27
1964 Johnson 40 hp electramatic shift: I noticed a small spot of lube under the motor about the size of a quarter, tracked that down to the seal behind the prop. decided to drain and check the lower unit lube and got a few table spoons of water first then blackish lube with white streaks. and not much of that. at the first seal up from the lower drain plug there was small droplets of water coming from where the lower drive unit attaches, no lube and no sign of lube ever leaking there just water droplets. Don't really know where to go next! is there a way to check the electric drive unit without starting the boat? Should have mentioned I just bought this boat and was told that it was marina maintained and stored indoors in the off season. I know I will have to replace the seals behind the prop but am worried about the seam where the drive unit attaches to the next section of the lower unit there seems to be no way of getting to the seal with out pulling the hole lower unit. Maybe fill the unit with lube again and see if it leaks where I am getting the water droplets? I know from searching these take premium blend or type c lube. I also know that if the electric shift unit is bad I have a major problem. I cant afford to throw money or time at this where its not needed.
