wings on your outboards????
MudLake
What is the correct name for those wings that people bolt to the cavitation plate and does it really help a tired outboard get up on plane?
cheers
arks
Re: wings on your outboards????
The generic term is hydrofoil.
MudLake
Why do people put hydrofoils on their outboards????
no subject
ezeke
Re: Why do people put hydrofoils on there outboards????
Good marketing.
ezeke
They will help to lift the boat when over-propped or under-powered. - They also provide substantial drag.
ezmobee
Two threads, same subject. I merged them.
outboardnut
to cover up a broken anti-cavitation plate
bktheking
Mudlake has posted before, I think its legit.
JB
When properly rigged, a hydrofoil, attached to the anti-ventilation plate.
Lowers planing speed, regardless of prop or power.
All of the negative myths about hydrofoils are supported by examples of being badly rigged.
ezeke
And most, if not all, of the marketing is supported by a paucity of independent, empirical data.
Silvertip
These things have been discussed to death in these forums. Those who favor them amount to about 1% of those who have actually used them. Look at it this way, if they provided any significant benefit the manufacturers would have designed the AV plate that way.
MudLake
this is what I really wanted to here.
Never had big enough motor to put one on and didn't know if they worked.
thanks
JasonAych
Bad news.
1)I am a firm believer that if there was a really good reason for it the engineers would have built it into it. Especially after all these years and different manufacturers.
2)Bushing and bearing killers. 2 friends of mine had the same outdrive, same year and almost identical hours. Only difference, 1 had a hydrofoil and his pivot bushing/bearings went bad at about 200hrs.
They do help keep the bow down. If you do a lot of skiing with a boat not purposed for skiing it may be something you want to consider. If not, I?d skip it.
phineas
I put a home made set on a 9.9 merc I have because I was running it on a boat with a 21" transom and the motor was a short shaft. I had only the one motor then and it was not very deep in the water. At a slow creep it was fine but once it got moving it would suck air. With the rig on the motor it would keep more water on the prop. It didn't take the place of a long shaft motor but I was able to use the boat.
ondarvr
You're correct, because only about 1% of the people have used them for what they can actually do and then set it up correctly to possibly get the desired results.
oldskool7_11
i put one on my boat. 14" tri-hull with a 50hp. the boat has better top end, planes faster and turns faster.
ddrieck
Wings are for airplanes and birds....
Tabs are for boats...
nuff said
Chris's CVX16
I've done tests on my boat. I can tell you I have no speed loss what so ever. I have better control. I plane quicker and stay up at a lower speed. I can turn much harder. And with my SE Sport 300 I can also get away with a lot more trim when getting up on plane (less wear/tear on my trim motor)
Proper setup is key.
Mine came with my motor so I didn't purposely go out and get one.
My little 100HP V4 is getting my boat up into the mid 50's with the hydrofoil. I am going to take it off when I install my new jackplate though. At least in the testing phase.
rodbolt
on my 19 ft thunderbird with an 85 120 jonnyrude they worked well.
its dangerous on my 18 hydrasports fish n ski with a 175 E-TEC. makes the back of the boat hop out of control on turns so I took it back off.
so do they work? some applications.
only testing carefully can tell.
just be CAREFUL while testing.
