dont know what year of my out board
lanejumper
i bought a boat and someone put a 85 Johnson javilin on it boat is a 90 but motor seems much older how can i tell the year so i can get a manual for wiring the boat has a key switch and so does the control box is that why tach and fuel gauge don't work?
ezeke
Re: dont know what year of my out board
The model number should be on a 1" X 3" metal plate attached to the port transom bracket.
Failing that, look for a nickel-sized, convex welch plug on the top of the engine block with the numbers.
Once you have the numbers, check back here.
lanejumper
the model number is 85etlr77s does that mean it is a 1977 thanks for any help
JB
Yes, Jumper. you are correct. It is a 1977.
ezeke
Yes, 1977. That's the last year in that particular series for the V4 85HP and 115HP. They were built from 1973 - 1977.
Use 87 or 89 US Octane gasoline with TC-W3 oil, Hi Vis gear oil. I had best luck using QL77JC4 Champion plugs and synthetic TC-W3.
See if there is any movement of the tachometer when you turn the ignition key to the run position. You may have a bad rectifier; check it according to this thread by Mr. Joe Reeves: http://forums.iboats.com/showthread.php?t=190638
lanejumper
thanks for all your help found out that gauges are still wired to boat but not to motor will fix that later i turned on the ignition switch on boat dash not control box has seprate key and fuel gauge worked was that engine set up for a temp guage dont have one on boat would like to have one on it took it out to lake today and found another problem i think it has a bad prop it seems to be cavitateing water when i plane out and turn hard right or left it looses power but moter sounds like it speeds up am i corect in my thinking and could i get a stainless prop for that engine and where would i find one so many to choose from on line
