FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I'm putting a new diaphram kit on the pump does any one think i should replace the check valves? It is a older motor. Holding them in hand and blowing in them they seem to work okay but there 27.00 bucks advice please
If your checking them in the fuel pump body by blowing in the gas inlet
and outlet and they check out I wouldn't worry about them. Diaphrams
are cheap, you can always replace them later if needed.
well i did and it sucking and blowing went both ways but when the guy checked them at west marine each one out of the body they worked fine. But i'll put them back in and test once more before i bolt it up
