What prop size and pitch should I have on a 1990 yamaha 150hp outboard? It is on a 21ft cuddy cabin.
M Michael Hagen Cadet Thread starter Joined Aug 16, 2008 Messages 16 Jan 27, 2010 #1 What prop size and pitch should I have on a 1990 yamaha 150hp outboard? It is on a 21ft cuddy cabin.
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,545 Jan 28, 2010 #2 Re: Prop size Ayuh,... Have a look Here,...
S steelespike Supreme Mariner Joined Apr 26, 2002 Messages 19,069 Jan 28, 2010 #3 Re: Prop size If you get us the info suggested we can probably help. At the least we need your present prop size (usually on the barrel or under the prop nut)and your present max speed and rpm.your motors rated max rpm would help as well.
M Michael Hagen Cadet Thread starter Joined Aug 16, 2008 Messages 16 Jan 29, 2010 #4 Re: Prop size It didn't come with a prop. Thats why the question
9 99yam40 Fleet Admiral Joined Sep 7, 2008 Messages 9,377 Jan 30, 2010 #5 Re: Prop size See if this will give you any info http://www.yamaha-motor.com/outboard/products/perfbull.aspx
