JustJason
- Aug 27, 2007
- 5,370
Re: Bravo 3 hard shifting
Agreed, if you can't shift this thing with 2 fingers using the engine bracket with the boat side cable disconnected its a 99% chance the lower shift cable is bad. It's a common item, they do "wear and tear" themselves out.
Still... find a new mechanic if yours is telling you to put new gears in your drive.
Don S said:Then see if you can shift it to fwd, neut, and rev. using the lever at the engine.
