treetopclimber
Thread starter- Joined
- Jan 25, 2010
- 11
Hello All...I have a 99' B3 that shifts hard into forward. Last year during fitting out, found that it would not shift into forward at all. Couldn't figure it out and took it in for repair. Mechanic found rear cover full of water from bad seal. Replaced shift kit and lubed. Shifts into forward but hard. Mechanic says cables are fine. He also informed me of the gear set upgrade. It never shifted "smoothly" to begin with, forward or reverse. I decided to go with it as is to see if I could live with it. After one season, I'm tired of it . It doesn't make docking any easier, which is already more difficult with the twin prop...I know I would have to confirm that it isn't anything else before going with the gear set upgrade , but I'm starting to seriously consider it. I've read the old posts on this subject, but I didn't see any outcomes . Has anyone gone through with this, and was it worth it ? I believe the cost for this job (parts and labor) to be around $1500.00 Is that in the ballpark ? Thanks...
