elkhunter338
Master Chief Petty Officer
Thread starter- Joined
- Jun 27, 2009
- 818
Since I am a starcraft guy and we tend to help each other out I have a question on replacement of a thermostate on an outboard. The Johnson/ section guys gave no help.
What I have is a 25hp johnson 1995 that I need to replace the thermostate. it is running cold.
My question is what type of substance should I put on the bolts that bolt the thermostate plate into place. what it has is grade 5 steel bolts into alum., they all came out ok, but have some corrosion.
What does the manual recommend or what in your experience works good so the bolts will come out again.
I was thinking marine grease, high temp anti-seize, or teflon pipe sealer (paste). I am leaning towards using marine wheel bearing grease.
Thanks
Thanks
