Re: Can 1708 biaxle cloth be stapled then epoxied?
Hookay... I wasn't gonna reply when I saw ondarvr did, but I feel the need to correct a few really poor ideas here.
First, the good stuff:
I have never seen a reason to use staples to hold glass in place.
Coat the wood and leave it sit until its hard, you can place the glass on it while its tacky if needed, but from the looks of what you're glassing you shouldn't need to.
I agree. Coat the surface of the glass or wood you're covering first, then let it soak up the resin some and get tacky. If needed apply more resin once it soaks in. You do this for two reasons:
- Wood will absorb resin, and if you put wet out glass on dry wood and simply roll out the bubbles, the wood may soak up enough resin to "starve" the outer fibers, creating a weak bond there.
- The tacky or wet resin can be used as an adhesive to put cloth in place, obviating the need for staples or adhesive
I use a foam roller and plastic squeegee for almost all glassing. I wet the surfaces, allow them to tack, then lay my pre-cut dry glass in place (assuming it's thin enough to saturate well) then roll/squeegee it out until it's transparent, adding more resin with the roller as needed.
The only time I wet out fabric before putting it in place is if it's so thick I have to roll/press in resin from both sides to fully saturate it. This would apply to something like 3210 biax/mat, or thick mat, or even 1708 with a thicker resin.
Now a few issues (according to me, anyway):
redfury said:
Staples aren't going to hurt anything, that's for sure ( use Stainless to avoid long term issues ).
Staples aren't red's idea here, just using him as a convenient scapegoat.
In most applications in a boat, staples are a bad idea to hold fiberglass in place for wetting. This is because of the way the reinforcing fibers function structurally. Fiberglass is strong because the fibers provide tensile strength and the resin keeps the fibers in place. Fiberglass works well for boats because it's flexible but strong. It "gives" where needed instead of breaking. This is why "hard spots" are a problem in hulls.. they're places where the fiberglass isn't allowed to give, and it therefore cracks and fails.
Putting staples in fiberglass creates a spot where the fiber can't move because it's firmly attached to the underlying wood. It creates a "hard spot" where the glass can't give. This may not be a problem depending on the function of the piece the staple is in, but it can also be catastrophic.
Stainless steel staples actually won't help here, by the way. Stainless avoids corrosion by forming an oxide layer in its surface. This coating keeps further corrosion from happening. If the stainless is placed in an area where there's little/no oxygen, it can start corroding because a new oxide layer can't form when the existing one is damaged. This is what's called "crevice corrosion". I'd think a staple inside fiberglass would be well protected from water, but if any got in there, it'd corrode.
Finally, if you can't get your glass to stay in place on a vertical surface, and you can't or won't use the method described above, then use a limited amount of 3m super 77 or super 90 spray adhesive to stick the glass in place. It'll hold dry glass well and doesn't cause any real problems with wet-out and strength of the eventual glass.
But if you use some creativity I think you'll find you don't need to use anything but resin to put the glass in place.
Erik
