225 vmax alarm Update good as new
epicguide
I have a 2003 OX66 225 vmax it is a tiller motor. i just had a new water pump installed
on the motor and the first time i took it out it runs fine when you are
on plane as soon as you come down off plane and start to idle around the alarm goes off it is a constant alarm if you turn it off and just turn key to on position it still goes off let it sit a few minutes and it is fine
I took it back to the shop and they said the trim indicater swich under the
motor was broke they replaced it and i am still having the same problem
I have never had a problem with it till they changed out the water pump
it only has under 300 hours on it
any help would be greatly apprecated
I am pulling my hair out
Thanks
Chris
DMSOUTH
Re: 225 vmax alarm
Re: 225 vmax alarm
Assuming they installed the water pump correctly, (a complete pump and not just the impeller), I would suspect the pressure relief valve had something stuck in it and it's open all the time....
epicguide
Re: 225 vmax alarm
Re: 225 vmax alarm
okay i just went and picked it up from the shop
when they did the water pump the first time they did everything
housing,impeller,plate
when i picked it up to today there was no paper work done so it
leads me to believe the plate may have been put in wrong or it was the wrong kit they
said they replaced the t-stat and the pr valves they said there was pebbles
in there but the motor has never not peeded i will see what happens when i take it out saturday
thank you for you response
DMSOUTH
Re: 225 vmax alarm
Re: 225 vmax alarm
If it had a pebble stuck in the pr valve, it would still pee. The problem comes when at idle and the pr valve is stuck open, water exits the exhaust instead of circulating to the top cylinders, resulting in an overheat. At speed, there's enough pressure for the water to reach the top, and the alarm will shut off.
rodbolt
Re: 225 vmax alarm
Re: 225 vmax alarm
post a full model number.
yamaha never made a tiller version of the Vmax 225.
trim indicator wont set any alarm horns,ever.
cannot install the plate incorrectly,simply cannot.
from your description,I would lean towards an oil level alarm due to a clogged remote filter.
if the pressure control valve was sticking,and they do, the longer you let it idle the hotter it gets and the alarm wont shut off at low speeds.
epicguide
Re: 225 vmax alarm
Re: 225 vmax alarm
vx225tlrc is the model *
epicguide
Re: 225 vmax alarm
Re: 225 vmax alarm
I guess my question is why has it never went off before not until
after i had them do them water pump? they did say to watch the tell tale
hole to make sure it continues to pee
They never showed me where the Pr is located is there a diagram some where
i can look at
epicguide
Re: 225 vmax alarm Update good as new
well to update i ran it today and it runs good no alarm and i did notice there
was no excess water comming out from around the exahust port anymore
i see what you mean about water staying in the top end
thank you for the help and ideas
