BigBoatinOkie
- May 28, 2009
- 763
Re: What makes a marine engine a MARINE engine
A little of both. I've been having trouble achieving the proper rpm range for the props I have. I've discussed props extensively in the prop forum. Based on the the prop I have now(18p alum 4 blade) I should be operating in the 4400-4600 rpm range. I'm only able to achieve about 3800-4000 rpm. Also the boat is quite slow to plane, and in my opinion a 4-blade 18p should get me outta the hole pretty quick. When I bought the boat, it was fitted with a ss 22p, which I would assume worked well for the PO at some time. It took forever to plane with that. Then I went to a ss 20p and it helped a bit. And now the 4-blade 18p. I could not reach recommended WOT RPM with any of the props. Like I said before, the trim tabs will help a lot, but I believe the engine is getting tired. I have not done any diagnostics on the current engine yet, and I figured if I was going to have to tear into it, I might as well swap to a better engine. But I'm still trying to listen to different angles and make my decision after some discussion with other boaters.
Sooo, are you looking to replace/rebuild your engine because it's tired or because of poor boat performance?
