Re: Interior almost done
Thanks for all the great comments everyone. The carpet on gunwales was already there and in great shape so I left it, the same with in the side compartments in the gunwales. My thoughts were to put vinyl on top where the carpet is but anything you set down on the gunwale stays put on the carpet but slides around on the vinyl. The vinyl was 74" wide and I used 34feet of it to do verything you see in the photos. The DekMaster glue is very bad for fumes and very expensive, and does not want to cure on aluminum or non porous surfaces, I used it on the last boat I did and was stoned for a week after, even with ventalation. This time I used regular contact cement on the areas where the vinyl was glued to aluminum and Latex contact cement on the wood area.
