can i put electric start on this motor?
tashasdaddy
Re: can i put electric start on this motor?
yes but it is expensive. minumum needed. starter bracket, starter, starter solenoid, battery, battery cables, wiring harness, ignition switch. then if you want it to charge the battery, you have to go into electronics, stator, rectifier, etc.
http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f
best bet is to find a blown engine with electric start, and use the parts.
imported_rusty
thanks tashasdaddy, I dont need to recharge the battery, so I just need the bare minimum, know any place where i can get the used parts from? anywhere close to n.j would be good, i think the model # isJRCTS thank you russ
tashasdaddy
good price.
1946Zephyr
Dammit, I wished Oregon Outboard Salvage was still open.:mad:
imported_rusty
I got a price for a used set up. 150.00 I just need to know if that includes the starter.
