Hx on Mercruiser
HVAC Cruiser
Here I have a real Newbee question Im about to ask
I just bought another boat today, This one although almost Identical to my 21.5' cruiser has an Mercruiser 260 I/O, the engine runs water/antifreeze through a heat exchanger that the other side runs what was previously fresh river water, soon to be ocean salt water. In the past I have only had outboards that ran salt water through them.
Is this typical for a I/O to have a Heat exchanger and a secondary pump for the sea/river water, or do I need to do some mods to go from fresh to salt water?
Don S
Re: Hx on Mercruiser
Heat exchangers are quite common on IO's, especially salt water boats. Does this Mercruiser have a year? They aren't all the same you know.
and what does Hx mean on Hx on Mercruiser ???????
HVAC Cruiser
Hi Don,
Thanks for replying its an 1984, the boat is solid, the outdrive is bad. This was used on the Hudson river for the most part, I know nothing about I/O boats, I initially picked it up to use it for parts I have the same in an outboard version , BUT it is to nice of a boat, it would be a Sin to do that to it. I figure I will fix it up and be a 2 boat family.
Any input would be great
Don S
Visit the Adults Only sticky at the to of this forum. You will be glad you did.
Just remember, having an 84 boat, doesn't mean you have an 84 engine and drive, so you might want to go searching for the Merc serial numbers to be sure what you have.
CheapboatKev
If I may translate Bills Shorthand..
(hirogliphics?)
Hx = Heat eXchanger?
P.S.
Thats a great looking boat there Bill..Now you need a home for 2???!!!!!:D
Don S
(hirogliphics?)
Duh :redface: I thought of everything but the most obvious :rolleyes:
Don S
My first thought was why he wanted to put a "Hex" on Mercruiser.
HVAC Cruiser
(hirogliphics?)
P.S.
Kevin, thanks for the translation yep the Hx is heat exchanger, I'm an HVAC guy, that's the abbreviation in my industry Oops:redface:
BTW guys if you saw my post on my hijack thread you'd know my wife has the hex on this boat covered :eek: Man am I in the doghouse over this one good thing its a cuddy cabin, I might need to sleep on her:eek:
sickwilly
abbreviations are jargon specific, are they not
Hx to my field means 'History'
Hx ETOH = history of alcoholism
Hx SA = history of sexual abuse
So I translated the post as History on Mercruiser
Great contribution to this thread, hugh!
