PreAlpa Lower Unit / Upper Gear Housing
BuzzM
Please confirm that no sealant ( like a gasket or perfect seal ) is required when reinstalling the lower unit back onto the upper gear housing. Just making sure.
thx.
Fishstick1962
Re: PreAlpa Lower Unit / Upper Gear Housing
No gasket or sealant is needed between these two parts. But if the unit is being used in salt water I would put some "Perfect Seal" on the bolt threads. This helps in removing them next time.
G-luck!
I/O WALDO
Don't forget the O ring around the gear oil passage.
