Re: Wavy Hull fix?
There is no easy way to get rid of waves in the surface and the longer the span of the wave, the harder it is.
Fiberglass tends to shrink over time, but on an older hull it should be done moving from it continuing to cure. It will also change shape from temperature and that will never stop, so depending on how perfect you want it, you may be chasing a moving target.
Epoxy sanding fillers will be more durable than polyester ones and if the hull is thin and flexes, polyester may crack if its very thick, it will also shrink and change shape more. Epoxy can be more difficult to sand though.
Just because the hull side flexes doesn?t mean its weak, it just means it flexes. Frequently in production boats products are used that reduce flex, but add nothing to the strength. Customers may perceive flex as weakness or poor quality, so for marketing purposes they try to reduce or eliminate it.
