jpatterson12
Thread starter- Joined
- Sep 2, 2009
- 24
I have a '67 Johnson 6HP Seahorse. The recoil spring is shot, so I aquired a new (used) one off E-Bay. The seller had nearly 100% feedback, and said the spring was working when he tested motor compression. I took down the old assembly, inserted the new spring, and tightened everything back up. Still no good. Is there a trick to installing a new spring? It can only go in one way vertically, and I've tried inserting the right-angle "keeper" end of the spring from both sides of the cut-away retainer pin. It seems to me that there ought to be a cutout, a groove, or a hole to put the bottom end, the other right angle end of the spring into, to stop the spring from spinning when you pull the rope, and create the tension needed to rewind the rope back in. Where am I going wrong?
