whats a good compression number
pedixon
Hi all
Getting ready to decarb my 1989 15hp evinrude, am going to buy a compression tester and check em , just wondering what should I expect for numbers. Never been decarbed before. Also a question about gas. Is there any benefit to running 89 octane vs 87.
PS - Welcome back bktheking
Thanks Phil
tashasdaddy
Re: whats a good compression number
no benefit for anything other than 87 octane, other than wasting $$$. rppe start motors, 60 -70 psi after 3 pulls. test before then after. also new fuel lines. ethanol. see the top secret file.
Whoopbass
A good compression reading will be around 90 psi. They will still run fine when the compression is 60lb+ psi.
A rope start motor will give you a lower reading then electric start since you can't get the motor spinning as fast. I think my 25 has a 15lb difference between rope and electric but used 25hp motors usually have around 100-120 psi and the are harder to pull so you probably wouldn't see the 15psi difference with your 15hp motor.
pedixon
thanks for replys
Phil
kenmyfam
Readings should generally be within 10% of each other for each cylinder.
