Re: fiberglass over alum skin
it doesn't say but the gentleman @ the marine said as lond as you coat it it can be added. i told him of the small holes i had in my hull and was going to use this product and then put a alum patch over it and he said to check it out that the alum patch might not be needed. i think i ran across this stuff on the boat where it was applied and had mushroomed into the transom from the PO and i had a hard time preping this area. 80 grit sand paper didn't phase it.... heck a grinder was tuff but finally leveled it out.
"Marine-Tex Epoxy Putty FAQ-
Is Marine-Tex Epoxy Putty safe for potable water repairs?
Marine-Tex is not rated for potable water repairs.
Can I drill and tap Marine-Tex Epoxy Putty?
Yes, after it has fully cured Marine-Tex is drillable and tapable.
Is Marine-Tex Epoxy Putty resistant to gasoline and diesel?
Yes, Marine-Tex Epoxy Putty is resistant to gasoline and diesel.
Can Marine-Tex be used to repair gelcoat?
Yes, please see "how to..." section for details.
How high of a temperature can Marine-Tex withstand?
Depends on pressure and conditions. Up to 250?F constant temperature in a dry environment, with spikes up to 300-325?F.
What does Marine-Tex adhere to?
Metal, fiberglass, glass, masonry, ceramic, wood, most plastics.
What does Marine-Tex NOT adhere to?
Plastics like polyethylene and polypropylene, and also any unclean, oily, greasy, or otherwise contaminated surface.
Can I pigment Marine-Tex?
Only the White Marine-Tex can be pigmented. No pure color will be achieved by adding pigments. (We recommend epoxy-friendly pigments, like Fibre-Glass Evercoat's.) Do not use more than 5% pigment per total volume of epoxy.
Which color of the Marine-Tex is better to use for machinery bonds?
Gray. The Gray Marine-Tex is stiffer in contrast to the White Marine-Tex which is better for fiberglass repairs.
Are there metal fillers in Gray Marine-Tex?
No, Gray Marine-Tex contains no metal fillers.
What is the shelf life?
Two years in a closed container at moderate temperatures.
What is the pot life of Marine-Tex?
Depends on temperature, half an hour at 72?F.
Can you use thinner with Marine-Tex?
No, it will change the physical properties of the Marine-Tex.
Can I apply Marine-Tex under the water?
Yes, but the Marine-Tex is likely to wash away in moving water while it is trying to cure. The FlexSet is better for underwater applications because it is of a denser consistency. If you would like to try an underwater application, mix the epoxy above the water, then deposit it on wax paper or plastic wrap. Slide the wax paper or plastic wrap onto the palm of your hand with epoxy facing up. Take it below the water line and apply to surface. Be careful not to smack or pancake the product onto the surface, this will trap water under the epoxy. Instead, roll the epoxy onto the repair to push water out of the way. Leave wax paper/plastic wrap on the repair while full cure takes place for best results.
Can I apply Marine-Tex in dry conditions on a below-the-water-line application?
Yes, the Marine-Tex is an excellent choice for repairing gouges or holes that are located below the water-line. Once cured, Marine-Tex is impervious to water and many chemicals. Since putties will go only where they are placed, be sure that the Marine Tex has completely encapsulated the problem area. It is a good idea to sand the perimeter of the repair so that the Marine-Tex achieves a grip on the solid surface around the repair.
Will this epoxy cure in cold weather?
Epoxies need heat in order to cure. If your application temperature is not at least 60?F you must apply heat to the area before, during, and after the application in order for it to cure. We recommend you place a shop lamp approximately 12" - 18" in front of the application. The lamp will provide heat at a constant rate, so that the material's temperature is always constant. Do not apply a heat gun or hair dryer to the area, these types of heat will heat the area too much.
