michelob77
- Nov 24, 2009
- 14
Ok yall I have been reading on this site for awhile but just now signing up. This is going to be a little long but want to give as much info as i can.
I have a 1998 90hp Force. I bought the motor back in July that was on the back of a pontoon boat I decided to buy and redo. Prior to me buying the motor it had been sitting for about a year. When I got it I cleaned gas tank, replaced fuel lines, new fuel filter, spark plugs, cleaned carbs, replaced the needles, new water pump impeller and thermostat.
The problem I am having is right now the middle carb seems to be flooding the motor, it is coming out the exhaust when trying to crank and front of carb. I have taken these carbs apart numerous times cleaning them. I finally broke down and took it up to a boat shop a few weeks ago and all they did was clean all 3 carbs some more and put another inline filter under the cowl. When I got it back it was running good and had it out on the lake a few times in the past couple of weeks and it ran just fine with full power.
This past sunday I took it out and tried to crank it when I got to the ramp and it never started just flooded. Brought home and saw that the middle carb is flooding again. Took them apart again and cleaned and put back on the boat and still flooding so I dont know what may be wrong. I am about to order a new float for the middle carb and a fuel pump diaphram kit just to replace it. I have taken the cover off the fuel pump before and it looked pretty good.
Maybe someone on this site can give me some info to try. Is there anywhere that I can just buy a new carb cause I havnt found one available anywhere.
I read where my center and bottom carbs are supposed to be the same is this true? Cause my middle is different.
The part numbers on my Tillotsen carbs are as follows:
Top 854449
Center 828308
Bottom 854450
Thanks
If you need anymore info on the motor just let me know and I will post it.
Top 854449
Center 828308
Bottom 854450
Thanks
