Here are the symptoms. I have a 1980 V4 85hp. It rarely will start without using starting fluid. The plugs look a bit wet. I've cleaned them and checked the spark and all seems well in that department. Once started, it doesn't have a lot of power. It used to do almost 50mph and now it will go about 35mph on a good day. I start it by clicking the key once and holding the choke for about 10 seconds. It will sputter and sputter but doesn't want to start. Also, when I shut down the motor I always see gas film in the water for a while. I'm not sure if this is normal. I did notice today that some gas is leaking somewhere and it left a small puddle in the back of the boat after sitting for a few days. Could this all be fuel related or is there something I'm missing? I wouldn't expect the plugs to be wet if it's not getting enough fuel. Thanks-Mike
