1994 Merc 60HP 2 stroke Rev limiter
arimatation
Does this have a rev limiter? Would be nice to know. Thanks
CharlieB
Re: 1994 Merc 60HP 2 stroke Rev limiter
No, the prop size determines WOT RPM.
arimatation
It does show a rev limiter on the CD service manual I have.
I do also realize the prop can let the engine rev too high with too little pitch.
But that was not really the question...........But thanks for the response.
CharlieB
It it always possible for me to be wrong.
Merc has built some ignition switchboxes with an RPM limiter circuit inside, but I don't remember any of those being used on engines less than V-6
Merc has also used an external idle stabilizer module (smaller black box that wires into the switchbox) These stabilizers advanced/retarded ignition timing to stabilize idle RPM. Often would become problematic at WOT and most recommend removal.
If you have a small black box that wires into the ignition module and NOT the temp sender or oil system, then you can safely remove it, eliminating another potential source of ignition problems.
arimatation
I have not seen the timing module mentioned......but thanks for the heads up. I will keep it in mind. Pat
