cleaning stains
big ken
hi. what is the best stuff i can buy to get off those nasty brown stains off my fiberglass hull? thanke ken
FAC
Re: cleaning stains
this is an often discussed topic, a search would yeild faster and more opinions about what you should use. i used toilet bowl cleaner, it worked well enough for my 10 year old stains
big ken
Re: cleaning stains
thanks, i did try some of that as well as bleech and water b ut didnt doo much, i dont think the guy ever cleaned this boat. i did a search after the post and found fsr to be hopeful but would like to know if there is anything better. would like to do this one time only thanks ken
ziggy
Re: cleaning stains
when i inherited my dads boat, which sat in the lake tied to a dock for summer after summer. it was pretty bad stain wise...
muriatic acid it the ticket. be very careful with it. it's real dangerous stuff.
i mixed it 1/4-1/3 acid w/ water. applied it with a spray mist bottle. get 2 or 4 bottles too as the acid will eat up the pump in short order and it won't pump anymore. used a long handle scrub brush and then rinse right away... then wash with boat soap and water behind that...
like i said, this stuff is dangerous... at the very least wear eye protection, a mask of some kind, rubber gloves. shoes, long sleeve shirt and pants, any thing ya can to protect yourself. and don't breath the fumes at all. you'll know if ya do i assure you...
if that don't cut the stains i don't know what will...
again. be careful if ya decide to use it. but i'll wager it'll get through the stains for you..
crazy charlie
Re: cleaning stains
The best stuff to use is On-Off by Marykate.The next best is FSR blue gel.Toilet bowl cleaner works well too,thats what I use but it sounds like your stains are worse that mine.Very very important to rinse well with water and WAX/POLISH before it hits the water again.
180Fisherman
Re: cleaning stains
Bleach won't do anything. Sno-Bol toilet bowl cleaner will take them off instantly and completely. It is a stong acid though so be careful.
big ken
Re: cleaning stains
i used some on/off by marykate stuff is fantastic, i couldnt beleive my eyes. funny though, when looking at add for it it says biodegradable. after buying it and reading the lable[yea rite!!!!!]
