peterskeeter
- Aug 24, 2008
- 86
Hello all, I can use some help with a possible ignition problem I'm having. I did a few searches and can't find too much. My 1989 90HP Evinrude Crossflow is acting up. 2 weeks ago on my way back in, the engine would all of a sudden drop RPM's when cruising around 4500 RPM. It would all of a sudden drop to about 3500 RPM and then bounce back up to 4500 in a minute or so and drop back down to 3500 RPM. Trying to see what it would do, I opened her up to WOT, and she would pickup to wide open and after a minute or so, cut out again. I figured it could be a coil pack dropping out as some looked old and one had cracks through the insulation. I changed all the coil packs with brand new ones and installed new plug wires. Took it back to the launch. It ran great for about 10 minutes and then back to the same old sh*t! Except this time it ran really rough and would not plane the boat anymore, had to put put back to the dock. Matter of fact, it would no longer even idle as it would kill. Perhaps it dropped two cylinders? Brought it back home and put it on the muffs and it sounded normal and would idle. I notice it is doing this when all the way warmed up. My temp alarm works but is not sounding when the motor loses power. My VRO has also been removed and I use premix. Any ideas? I hate to throw more money at this with no fix. Sorry for the long post. All ideas are welcome. I am competent at working on these things but the ignition on this motor I find to be complex! i wish it had points!!!
