warning horn test for the temp sensors
piperdog
hello,cant find this in my manual ,can some one run thru it for me ,,thanks piperdog
1988 ,90hp v4 evinrude
Re: warning horn test for the temp sensors
If you disconnect the temp sensor wires on each head, and ground the wires, the horn should sound.
Ignition needs to be on. Motor can be running or not.
Rocky_Road
I have an I/O, but I am going to take a 'stab' at this....
Most temperature switch horns can be tested by simply grounding the switch's lead to the engine block, with the key in the 'on' position.
As for the switch itself, I have never seen a test that didn't require putting it into hot water on the stove top, and reading the electrical resistance as the water reached the switch's trigger temperature. I have always assumed that it would be easier to replace any suspect switch, than go through all of those 'hoops'!
Happy boating!
