1990 Bayliner Capri 20' / Battery Post
gypsee57
I have a 1990 Bayliner Capri 20' that I just restored. I am having a problem with the battery post melting. When I crank the boat it gets warm. Till the gas pumps up the post continuest to get hotter and hotter and has melted the post. Once it starts the post cools off. Does anyone have any recommendations as to why and what I should do to correct this problem.
Rocco,
Florida
ezmobee
Re: 1990 Bayliner Capri 20' / Battery Post
This sounds like more of a problem with the engine than the boat itself. As such, you'd get better answers if this were posted in one of the engine repair sections. If you let me know what motor you have, I'd be happy to move this thread. Welcome to iboats!
gypsee57
I have a I O 135 Merc Cruiser 4 cylinder.
Any help is greatly appreciated, thanks
Rocky_Road
If this were mine, I would be starting at the engine block ground cable. Don't just inpect it...take it loose, clean throughly, and reattach securely.
Happy boating!
ezmobee
Thanks. Moving to I/O repair.....
Bt Doctur
Starter motor drawing excessive current
battery cables loose corroded
auto type end s(steel vs copper)
Ayuh,.... Welcome Aboard,....
I see that you have 2 Problems,....
1st off, the motor needs a Tune Up,+ probably a Full Service...
You shouldn't have to Crank it on the starter so Long to start it....
Something is Wrong,.. Fix it...
The Other thing is, as noted, your wiring needs to have All the connections taken apart, Cleaned,+ reinstalled...
The Heat causing the melted battery is because of Resistence from corroded connections,...
The Melted 1 was no doubt the Worse 1...
Or just a Cranked out Beat starter... which wouldn't surprise me either....
zbnutcase
And make sure you are tightening the connections at the battery with a wrench or pliers-hand tightened wing nuts are a disaster waiting to happen. 'nutcase
bruceb58
If you do have wingnuts, ditch them and get locking stainless steel nuts.
lowkee
In order to give advice, I would need at least inside and outside photos of your boat :D
