Re: 1985 Evinrude lower unit removeal
In my case (on a '81 Johnson 90) no I didn't remove the carbs, although I did have to remove some fuel hoses that were in the way. There's one bolt that holds the shift rod end in the linkage, and yes, the shift rod will come out with the lower unit.
Getting that bolt back in was the hardest part of the entire process. I finally took a piece of 14 ga. house wire, put a loop in the end so I could keep the bolt from falling out of my socket wrench, and once the bolt had gone in a few turns pulled the wire out.
