evinrude 15 powerhead swap
JTROCKS1
Does anyone know if a 1976 evinrude 15 powerhead fit on a evinrude 1979 lower unit. I know the electronics are different. I'm concerned about the driveshaft and bolts matching up.
bktheking
Re: evinrude 15 powerhead swap
The powerhead should bolt up, the shifter components were plastic in 79 and metal in 76, but they are interchangeable. I've had a 75 , 83 and 88 9.9 (same motor essentially less carb and a couple other components) powerhead, all the bolt holes are the same, less starter stuff.
Faztbullet
According to Brp the 1974-76 use the same shaft but the 1979 is totally different so I doubt it will swap.
JTROCKS1
shopevinrude.com is showing a drive shaft part number of 0387606 and 0321455 as an alternate for the 76 model. The 79 model is showing a 0321455 so I think I'm OK driveshaftwise.
