water in the oil pan help!!!
attila nagy
I have a 302 i/o.I drained 10 gallon of water oil mix out.I pulled the exhaust manifold off.The plugs perfect shape the chamber is cleen as a whistle no sign of water at all.
Where is the water coming from?
Ideas?
Please:confused:
Bt Doctur
Re: water in the oil pan help!!!
Cracked block,corroded hole in the intake manifold
attila nagy
Is it a part of the block or a separate cover?
Bt Doctur
Just a timing chain cover,sep from the block.more than likely NLA ,but if you decide to use a car cover you will have to changeover to FWC (A/F)
StevNimrod
What is the NLA means?
No Longer Available.
Just went through the same thing with my motor: water in the oil and it was a fresh rebuild. Turns out to be a cracked block. Once you start troubleshooting the guys here will help you track it down. Hopefully you're not in the same boots as me.
attila nagy
That is not what i want to hear.Well i have to see first>
thanks for your help
Druff1
this = this
attila nagy
Did you see any sign of water inside of the had or on the spark plugs?Or on the manifold?Any brown coloring?
attila nagy
Is a compration check would tell me if a have a cracked had or a blown had gasket?
Knightgang
A compression test will tell you if your cylinders will hold pressure (compression). If you have low compression, could still be several things, cracked block, cracked cylinder wall, cracked head, blown head gasket, cracked or blown piston, spark plug not properly seated, or cracked plug, bad valve seats, bent valve, etc. The list goes on, but it does narrow the search...
StevNimrod
Just keep in mind that the key to the compression test is knowing how to interpret the results. On my motor, on the offending bank (cylinders 1,3,5,7) the compression was 150-160 on 3,5,7 but over 200 on cylinder 1. That was because water sitting on top of the piston made the compression chamber smaller leading to higher compression.
Only way to get further is run the test and report the numbers.
attila nagy
thank you.I will report back.If water was on the top of the cylinder should i see signs of it?
