maildude1960
Thread starter- Joined
- Apr 26, 2009
- 8
Starting out, it would not idle and had very little power. Pulled the carbs and reed plates off and found it had a broken reed. Replaced the block, put it all together and now it idles very erraticly and very high (2000-3000 rpm) and spits and sputters. Sounds like your gunning a chainsaw. I pulled the carbs again and soaked them. Still the same. You can cover the top carb, little change, cover the bottom carb, immediately dies. Pulling the bottom 2 plug wires slows it down. Also turns over very slow with fully charged battery and seems to smoke heavily. Please help!
